jonishumaker's avatar
jonishumaker
Follower
Mar 12, 2021
c7000v2 port 8883
Let me start off by saying I am not tech savvy at all. I purchased a new garage door opener (lift master) that has myQ technology. I can connect it to wifi and use an app to open and close the garage door. I cannot get it to connect to my wifi. When I contacted the support team, they said that my wifi does not have Port 8883 opened. They sent me a link but I do not know how to fix it. I logged into my router and did a TCU add for that port, but it still will not connect. I do not know what else I need to do. Anyone have any suggestions or have you had to do this before? I have a netgear c7000v2.
https://support.chamberlaingroup.com/s/article/Recommended-router-settings-for-the-MyQ-Wi-Fi-products-1484145723404?name=Recommended-router-settings-for-the-MyQ-Wi-Fi-products-1484145723404
That is the information that lift master provided me. Thank you for your help!
1 Reply
  • > [...] I have a netgear c7000v2.
       Is that your only router?
    > [...] I can connect it to wifi and use an app to open and close the
    > garage door. [...]
       "it"?  Does that mean that you _can_ connect the opener to your
    C7000v2, or only that you should be able to, or what?
    > [...] I cannot get it to connect to my wifi. [...]
       "it"?  Because "can" and "cannot" are not consistent.  Is the problem
    that the opener can't talk to your router, or that the opener can't talk
    to Chamberlain's computer, or what?
       "cannot" is not a useful problem description.  It does not say what
    you did.  It does not say what happened when you did it.  As usual,
    showing actual actions (commands) with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
    > [...] I logged into my router and did a TCU add for that port, [...]
       I don't know what that means.
       That suggests that there's an LED on the opener.  With my weak
    psychic powers, I can't see yours from here.
    > [...] I am not tech savvy at all. [...]
       You don't need vast expertise to say what you're doing, and what
    happens when you do it.
