Itsbiggs22
Apr 28, 2019Tutor
C7000V2 Rebooting itself
Apparently you only get 90 days of support which is franky pretty crap. I have always used netgear and maybe that is my mistake. I got this router/modem on Jan 24 2019 and it most recently this mon...
michaelkenward
Apr 29, 2019Guru - Experienced User
The warranty period is for at least a year, depending on where you are.
- Itsbiggs22Apr 29, 2019Tutor
Warranty is, correct. However they don't even let you contact support about issues outside of 90 days.
- michaelkenwardApr 29, 2019Guru - Experienced User
Itsbiggs22 wrote:
....they don't even let you contact support about issues outside of 90 days.
Login to MyNetgear:
- My Support
- Contact support
- Replace my defective product
- Select a Product
- Contact NETGEAR Support
Immediately jumping to replacing a product seems silly instead of just allowing a firmware downgrade or the such (It wont let me manage firmware said its handled by ISP)
