RD1111
May 05, 2022Aspirant
C7000V2 reset disrupted wireless connectivity for some devices
This router had been working wirelessly with no issues in a home environment with two PCs, two iPads, two Android phones, and an HP printer. Yesterday, the router was briefly disconnected from power...
May 05, 2022Guru - Experienced User
Try disabling WiFI Private IP address feature on your iPhones and iPads:
- RD1111May 05, 2022Aspirant
Thanks for suggestion. Unfortunately, disabling private wi-fi address had no effect. Same issue persists.
- FURRYe38May 05, 2022Guru - Experienced User
Try a Forget this Network on the Apple devices then try to re-connect.
What channels do you have set on the modem?
Is Smart Connect enabled on the modem?
As a quick test, set WPA security on wifi to NONE. Do these devices connect then? Re-enabled WPA2 and AES after testing this.
