PFein
Jan 05, 2024Follower
C7000v2 resets to factory when Cox does maintenance
My C7000v2 performs a factory reset when Cox does a maintenance outage. This resets everything, requiring me to hard cable into the modem and manually change the SSIDs and passwords. This has happened...
Jan 05, 2024Guru - Experienced User
Something to ask the ISP about. If there doing maintenance then there doing something to the modem. There responsible for the signal up to the modem.
Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed or something happens.
