Brashke
Dec 13, 2022Aspirant
C7000v2 Resets when ISP Performs Server Maintenance
My router resets to factory defaults each time the ISP (Cox) does server level system maintenance. This makes no sense to me. Each time, the router needs to be reconfigured back to the prior sett...
Dec 13, 2022Guru - Experienced User
Id ask the ISP if they are trigging a reset when then do this from there side.
Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed or happens.
- BrashkeDec 13, 2022Aspirant
Per the ISP, they are not triggering a reset.
Re: Backing up Configuration, I can reset the router settings back to what they were in a few minutes. But, then, every device needs to be attended to get each to connect to the established network; even though it is exact same SSID and PW
- FURRYe38Dec 14, 2022Guru - Experienced User
Do you have a recent or current back up configuration file to use?
- BrashkeDec 14, 2022Aspirant
Having a backup config is not necessarily the issue. It takes little or no time to reconfig back to same/prior settings. The issues is that once done, every single connected device needs to be manually reconnected to the reestablished network.
Unless I am missing something, I do not think the backup config saves me the latter process. Do you know different?
Further, this typically happens when I am not there. Hence, all my security (among other things) goes offline.
