brm5124
Dec 27, 2020Tutor
c7000v2 resets
I am getting frequent modem resets. The event log states:"Received Response to Broadcast Maintenance Request. But no Unicast Maintenance opportunities received. T4 time out, CM MAC=38.94 ed: dd:f4:c...
- Dec 28, 2020
You're power levels are out of spec. They should be within 3.5dbmv of each other. Yours goes from 4.3dbmv to 10.7dbmv. A 6.5dbmv difference. a little variation is fine but that's quite far.
If they're saying the lines fine, maybe it is indeed a modem issue. You can always try renting a modem from the ISP for a month. If it works fine, it could be the modem. If there's issues, then the ISP can't blame the modem.
It could also be that the ISP gave you a docsis 3.1 device which is a little more tolerant of power fluctuations/levels.
Jan 04, 2021Guru - Experienced User
glad to hear it helped!
brm5124
Jan 17, 2021Tutor
I spoke to soon. After about 3 days the unit started acting up again.
I am currently renting a Modem from Cox. After six days it has not reset once.
I plan to let it run for 2 weeks
If no resets on the rental then I will request a warranty repair, on my Netgear unit.
