MitchT
Aug 22, 2019Aspirant
C7000v2 Router reset and now shows factory network names and passwords
I came home and noticed my internet was out. I expected it was a Cox issue. An hour later, and after all the fixes from the Cox rep. didn't work they determined it was likely a setting on my route...
michaelkenward
Aug 22, 2019Guru - Experienced User
Your subject says C7000v2, that's a cable modem/router. Your footer says A7000. (That's a WiFi USB Adapter.)
Your message appears in Nighthawk WiFi Routers. That's something else altogether.
You might get better and quicker replies, and find other answers, over in the appropriate section:
Cable Modems & Routers
