dhaze68's avatar
dhaze68
Follower
Jan 29, 2021
c7000v2 setting the time zone
Hello,
I've got a c7000v2 with Spectrum internet. I'm on firmware 1.02.09 and can't upgrade because it's on the ISP.
On Win10 and accessing my Router via the web interface using Chrome.
I'd like to change the time zone because the time is 5 hours off. As per the manual I'm on the "Schedule" page but there is no drop down for selecting my time zone. If I go to add a schedule there is no entry for time zone either.
Any help is appreciated.
Thanks
1 Reply
  • > [...] I'm on firmware 1.02.09 and can't upgrade because it's on the
    > ISP. [...]
       If you're looking for reasons to complain about your ISP, ...
    > I'd like to change the time zone [...]
       I'd suggest a Web or forum search for terms like, say:
          cable modem timezone
       I found, among many other things:
          https://community.netgear.com/t5/x/x/td-p/1916774
          "[...] the time is updated by the ISP and cannot be changed
          manually."
          https://kb.netgear.com/000061048
          "Cable Modem Routers use the time provided from the service
          providers [...]"
