jhscott
Oct 08, 2019Aspirant
C7000V2 shows "Critical" - Under hardware warranty. Need return shipping address.
I received a case number and do not want to purchase phone and email support as my router/modem is still under hardware warranty. I was told that I would receive an email with shipping information fo...
Oct 08, 2019Guru - Experienced User
Did you open a support ticket here?
https://www.netgear.com/mynetgear/registration/login.aspx
I would if you haven't or if you have, keep in contact with NG support here about this.
All RMA and support is handled here. Nothing we can do here in the forums.
- jhscottOct 08, 2019Aspirant
I haven't, but I believe I am unable to because the only thing covered under warranty is the hardware (no email or phone support). I wasn't sure what to do if I've already called them, told them the issues with router/modem, they said they would email me the shipping address and directions in order to start the return and they just emailed me a troubleshooting link and nothing else. I'm at a loss. ¯\_(ツ)_/¯
- FURRYe38Oct 08, 2019Guru - Experienced User
Did you get a case#?
If you did, call them back and ask about the email and that your waiting to recieve this information. Might ask them to send this information while your on the phone with them.
I did get a case #. I was trying to avoid the same 25+ min wait/call without the info emailed, but if this is the only way I will certainly try that again. Thank you.
