sootysax
Nov 30, 2020Follower
c7000v2 Slow download speeds - Optimum 200
My download speeds have become unbearably slow. I pay for 200mb/s and my speedtests are averaging 20-30mb/s. Upload speed are normal. I called Optimum and they say they are getting full speed ...
Nov 30, 2020Guru - Experienced User
Do you have a screen snip of your cable connections page and logs? That helps us check the connection and not optimum. Their go to response is "our lines are fine".
If you have any splitters, amplifers, or attenuators in the coax line, remove them.
