Gryme02
Jul 25, 2019Follower
C7000v2 slow internet on Spectrum
I have a C7000v2 that "should" be capable of speeds up to 960Mbps, but using it as modem with my Spectrum internet, I am usually getting an average speed of 10-50 Mbps. I talked to Spectrum and they ...
w3rn3r_Riv3ra
Nov 03, 2019Aspirant
The above information might not be accurate, as the modem router that they provided me with is a 'Arris TG1672G' which is a DOCSIS 3.0 Dual Band, I have the 300mbps service and once I switched the router modem with the 'AC1900 -model C7000v2 DOCSIS 3.0 my speeds dropped to 100mbps and uploads to 11mbps, this just makes me think that they lowered the speeds. horrible spectrum.
- FURRYe38Nov 03, 2019Guru - Experienced User
You'll need to contact your ISP and have them help you with getting the C7000 speeds up. They need to check the signal and line quality UP to the modem.
Be sure that there are no coax cable line splitters in between the modem and ISP service box.
Be sure you are using good quality RG6 coax cabling up to the modem.
Your issue has nothing to do with DOCSIS versions.
w3rn3r_Riv3ra wrote:The above information might not be accurate, as the modem router that they provided me with is a 'Arris TG1672G' which is a DOCSIS 3.0 Dual Band, I have the 300mbps service and once I switched the router modem with the 'AC1900 -model C7000v2 DOCSIS 3.0 my speeds dropped to 100mbps and uploads to 11mbps, this just makes me think that they lowered the speeds. horrible spectrum.
