overbeck
Sep 21, 2021Follower
C7000v2 slow internet on the 2.5 GHZ WIFI
Replaced my Xfinity ARRIS box (died cmpletly) with the C7000v2 but my 2.4 wifi speed only gets to 40-50 mbps tops! my service is good to 200. the 5G WIFI perfoms ar normal 180-220 MBPS. what ...
Sep 21, 2021Guru - Experienced User
Depending upon your connected client device support and design and connection rate, you'll not see much near same speeds as 5Ghz with 2.4Ghz.
