JWhid
Jun 25, 2020Aspirant
C7000v2 slow speed
I’ve had my C7000v2 over a year now and recently upgraded my Spectrum service to 200Mbps. Since the update I’m only getting 70Mbps. After spending all day on the phone with Spectrum trying to resolve ...
Jun 26, 2020Guru - Experienced User
1. Do you have a screen snip of the cable connections page and logs? those help check connection back to the isp?
2. Did you have them reprovision it? it wouldn't be the first time it was provisioned with the wrong file.
3. How are you testing the speed? For any speedtesting, a hardwired connection is best. And you want to make sure that its a computer that can handle gigabit speeds.
4. What device are you testing with?
JWhid
Jun 26, 2020Aspirant
Not sure what you mean by your first two questions, haha. I did the test with an Ethernet cable attached to my MacBook Pro.
