Vaalko's avatar
Vaalko
C7000v2 Slow USB Throughput
Greetings,     I have a C7000v2 - Nighthawk AC1900 WiFi Cable Modem Router that has a Netgear approved usb HDD(not self powered) connected to the rear USB port.  I use the HDD for a media server tha...
  • FURRYe38's avatar
    Nov 07, 2019
    I would guess that the USB port on the modem may not be supporting of high bandwidth data flow which 4K is.
    USB 2.0 port is what is supported on the modem. If the port was USB 3.0/1 then this would probably not be a problem.
