forceraoul
Nov 13, 2019Tutor
c7000v2 Spectrum internet says repeatedly trying to update firmware
I have the c7000v2, hardware 2.01, firmware 1.02.09 which seems to be the latest for Spectrum internet. This morning, it repeatedly bogs down, about once per minute, internet becomes slow or nonexist...
Nov 13, 2019Guru - Experienced User
Spectrum is the one who pushes updates to combo devices. Not netgear and not the user unfortunately.
If you pull up your modem connections page, take a screen snip of your upload/download connections. if your signal connection is bad, it can cause similar issues as well as it can have issues with updating (if it truly is).
- forceraoulNov 13, 2019Tutor
I just spoke with Spectrum again and they insist the opposite, that only netgear can push a firmware update, I spoke to escalation as well who said the same. They say only netgear can fix this or stop whatever update loop is going on.
Seems Spectrum is now confessing to an area-wide problem, just like them. We'll see if they fix it and that resolves.
- FURRYe38Nov 13, 2019Guru - Experienced User
Remove the coax cable from the modem then press the reset button for 15 seconds. You can try to setup the modem with out the coax cable being connected. if you can. Complete the setup wizard then connect the cable.
Hopefully this is an isp problem.
