forceraoul
Nov 13, 2019Tutor
c7000v2 Spectrum internet says repeatedly trying to update firmware
I have the c7000v2, hardware 2.01, firmware 1.02.09 which seems to be the latest for Spectrum internet. This morning, it repeatedly bogs down, about once per minute, internet becomes slow or nonexist...
forceraoul
Nov 14, 2019Tutor
Seems Spectrum is now confessing to an area-wide problem, just like them. We'll see if they fix it and that resolves.
Nov 14, 2019Guru - Experienced User
Remove the coax cable from the modem then press the reset button for 15 seconds. You can try to setup the modem with out the coax cable being connected. if you can. Complete the setup wizard then connect the cable.
Hopefully this is an isp problem.
