timandmarilyn
Nov 06, 2023Guide
C7000v2 Speed Issues
Hello, Recently we were told by our ISP (Spectrum) that our Internet speed has increased from 100MB to 300MB. Not only did this not happen, but our upload speeds are now nonexistent when connected v...
- Nov 18, 2023
Thanks FurryE38.
Well I have an update! Spectrum came out and replaced the line due to errors they saw, but it didn't resolve my issue. HOWEVER, they tested with the ethernet cables I was using and verified upload speeds worked fine ... so it isolated my upload issue to the PC. After researching extensively further, I discovered that people have been complaining for months about the "Killer" ethernet software that a firmware update caused it to kill upload speeds :). There's literally a single switch in their control panel you can punch to fix it, which I did. So Netgear is off the hook officially on this one :).
On the WiFi side, uploads have always been fine. The download speeds bumped up tonight after the improvements, but still not to 500mb ... its stuck at around 300-350. Well I was told by Spectrum that despite my device being able to handle 1.9GB, Spectrum only supports up to 400mb on that device, so that is tracking with what I'm seeing. I was only aiming for 300 in the first place anyway. Strangely, the PC that's physically connected is still well over 500mb regardless of what they say.
So bottom line the mystery is solved ... partly a line issue, partly a software issue. Thank you for the help in thinking this through FurryE38!
Nov 29, 2023Guru - Experienced User
I believe this "Prioritization Engine" feature is located on the Killer adapter cards control settings. It won't be seen on the NG side of things. This is a feature of the Killer ethernet adapter card. Do you have this card?
swingtime
Nov 29, 2023Aspirant
Thanks Furry 38. I do not have the Killer Ethernet Card. Only have the Netgear AC1900 C7000 Version 2 Cable Modem Router. ISP deliver speed showed down-speed of 250-300 mBS when the Spectrum Tech checked the line going to my C7000V2. Once he reconnected the line to my C7000V2 last night, I was getting 200+ mBS at my laptop and on a phone. 20 minutes later the down-speed signal strength down-speed dropped back to 1mBS. Figuring I need to replace my modem router. But may try a Toner Cable Co RPA42-Return Path Attenuator at the cable to modem-router connection if I can determine the correct dB level to order. There are 3, 6, 9, 12 & 15dB attenuators.
- FURRYe38Nov 29, 2023Guru - Experienced User
OK so your problem will not be the same as the OP.
Let start a new post for you in this forum and we'll see if we can trouble shoot your issue.
- timandmarilynNov 29, 2023Guide
Yes to Furrye38's comment ... swingtime it looks like you have a different issue than ours - good luck on the new thread!
