timandmarilyn
Nov 07, 2023Guide
C7000v2 Speed Issues
Hello, Recently we were told by our ISP (Spectrum) that our Internet speed has increased from 100MB to 300MB. Not only did this not happen, but our upload speeds are now nonexistent when connected v...
- Sep 28, 2017
Hi NotFox,
Did you use this driver version?
https://kb.netgear.com/26927/WNA3100-Software-Version-2-2-0-4-Supports-Win8-8-1
swingtime
Nov 29, 2023Aspirant
Thanks Furry 38. I do not have the Killer Ethernet Card. Only have the Netgear AC1900 C7000 Version 2 Cable Modem Router. ISP deliver speed showed down-speed of 250-300 mBS when the Spectrum Tech checked the line going to my C7000V2. Once he reconnected the line to my C7000V2 last night, I was getting 200+ mBS at my laptop and on a phone. 20 minutes later the down-speed signal strength down-speed dropped back to 1mBS. Figuring I need to replace my modem router. But may try a Toner Cable Co RPA42-Return Path Attenuator at the cable to modem-router connection if I can determine the correct dB level to order. There are 3, 6, 9, 12 & 15dB attenuators.
Nov 29, 2023Guru - Experienced User
OK so your problem will not be the same as the OP.
Let start a new post for you in this forum and we'll see if we can trouble shoot your issue.
- timandmarilynNov 29, 2023Guide
Yes to Furrye38's comment ... swingtime it looks like you have a different issue than ours - good luck on the new thread!
