Wolfgang123
Oct 03, 2020Follower
C7000v2 starting frequency
I just want to know what the recommended starting frequency is because I have lots of correctable and uncorrectables
1 Reply
I'd recommend removing any splitters, amplifiers, attenuators for the coax line.
check for kinks, damage, cheap connectors/band connectors.
If you've done all that and are still having the same cable connection stats, the ISP needs to check the line.
