ldjessup
Mar 09, 2020Aspirant
C7000V2 trying turn on built-in VPN
Figured out how to turn on built in VPN, but Amazon would not run. Turned it off without taking any notes and now would like to turn it back on and can't remember where the softwarre switch is locat...
- Mar 10, 2020
You might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Cable Modems & RoutersNo need to repost there, unless you want to – that will just clutter up the place with duplicated messages – but you might find advice related to your hardware.
I have asked the Netgear moderator to move your message.
michaelkenward
Mar 10, 2020Guru - Experienced User
