jmartinezmp
May 02, 2019Aspirant
C7000v2 Unable to display router webpage after some time
After some random time (24 hours+), I am no longer able to connect to the router via the web browser (10.0.0.1).
As a workaround, I need to restart the router. I am then able to make the necessary ...
May 02, 2019Guru - Experienced User
How frequently is this happening?
When it happens, can you ping the combo device?
Does the internet still work when this issue happens?
Have you tried a different browser when it happens?
What firmware is it on?
You could try doing a factory reset and set it back up from there. Hold reset for 7-10 seconds.
You can backup your configuration and re-use this or hold off and do it the manual way. Helps to reduce chances of an errant setting causing the issue.
jmartinezmp
Hello, see answers below:
Always. Every time I need to return to the router to adjust something, I need to restart it.
Yes.
Yes. Everything else is fine.
Yes. IE/Chrome/Firefox.
I'll get back to you on that one later tonight or tomorrow.
Answer: I'll reach out to Comcast (oh dear...) as they are the ones that manage the ISP setup and I don't want to risk too much downtime. But I do recall that we attempted this before, yet problem persisted.
The first configuration was to add Comcast as ISP. After a few days, I tried to login again to add my port forwarding and additional setup, but encountered the issue for the first time. Perhaps it's an issue with Comcast's own firmware or something. I think they manage their own.
Thanks for the quick reply!
