jmartinezmp
May 02, 2019Aspirant
C7000v2 Unable to display router webpage after some time
After some random time (24 hours+), I am no longer able to connect to the router via the web browser (10.0.0.1).
As a workaround, I need to restart the router. I am then able to make the necessary ...
jmartinezmp
May 05, 2019Aspirant
Hi everyone,
2019-05-05, Comcast: They do not manage the router, only need to know the MAC address to send the signal. They do not have their own firmware (however, I do recall they did something about firmware during the initial install, but can't remember what it was).
Netgear, C7000v2, Firmware version 1.02.14.
I don't see any firmware download page for the product. I was able to find the Genie software for my computer, so I'll start getting used to it. Any newer firmware?
I have now restarted the router. If it becomes unresponsive again via web browser, I'll try the Genie software. Then the next step will be to factory default.
Thank you.
May 06, 2019Guru - Experienced User
ISP handle ALL FW on cable modems. NG provides FW as needed or as updates come out from NG directly to the ISP for further testing then the ISP pushes, if any to cable modems.
Let us know how the factory reset and setup from scratch goes. Try Different browsers. IE11, FF or Opera.
