jmartinezmp
May 02, 2019Aspirant
C7000v2 Unable to display router webpage after some time
After some random time (24 hours+), I am no longer able to connect to the router via the web browser (10.0.0.1).
As a workaround, I need to restart the router. I am then able to make the necessary ...
jmartinezmp
May 12, 2019Aspirant
Hello everyone,
So, the issue returned as of this morning... about exactly 7 days after I restarted the router.
When I try to access the router via the browser (IE, Firefox, Chrome), there's just an never ending "Waiting for 10.0.0.1..." status and doesn't even timeout. See attached "2019-05-12_Netgear_Router_Web Access Issue.JPG" file.
I didn't do any modifications to the router since the last restart on 05/05. I simply restarted it, and saved a backup of the configuration. During the following days, I simply opened the browser and was able to login and logout for testing purposes. Today, I was about to do the same but encounter the issue.
I'm now going to default, then I'll update this case again next weekend.
Please let me know if you've seen this issue before.
Thank you.
jmartinezmp
May 26, 2019Aspirant
Hello Everyone. Just to update this thread.
It's been over 2 weeks now that I defaulted the router and used the basic configuration (kept the 192.168.0.1/24 instead of my usual 10.0.0.1/24 network). Simply set WiFi password. No port-forwarding, etc... I just managed without it.
I can no longer reproduce the problem, at least for now.
Thank you for your suggestions.
- FURRYe38May 27, 2019Guru - Experienced User
Glad you got it working. Enjoy. :smileywink:
jmartinezmp wrote:Hello Everyone. Just to update this thread.
