Sodamnannoyed
Oct 03, 2020Aspirant
C7000v2 Upstream Fail. Constant signal loss, all green lights
I have had consistent problems with Upstream since moving in. The upstream light would turn orange and the TX would be 50-57 on one channel. The modem would subsequently reboot. Rinse and repeat x5-6 ...
Oct 04, 2020Guru - Experienced User
Do you have a screen snip of the cable connections page and the logs?
That helps.
I'd remove any splitters, amplifiers, or attenuators you have in your line.
