pinkstonms
Aug 20, 2023Tutor
C7000v2 V1.03.02 but Netgear says V1.03.08 is most up to date driver
the driver installed on my Netgear C7000v2 is V1.03.01 but your website says the most recent is V1.03.08. How can I get the most recent installed no option on the C7000v2.?
pinkstonms
Aug 21, 2023Tutor
Thanks for the reply house is one level 3700 sq ft. Sits on one acre. Have a pool and deck in back yard and need to get WiFi out there. Maybe 30 feet from back door. We have a bunch of devices, Alexa’s, laptops, iPads, cell phones. There are two of us living in the house.
Aug 21, 2023Guru - Experienced User
I'd look at the 7/8/9 series of orbi's with 1-2 satellites.
You've got a solid-sized home and want to cover the outdoors so its better to over engineer a bit than under.
And the VR takes a bit more stable and faster throughput.
So I'd look a little higher end. The C7000 is quite old and probably struggling a bit.
With that said, it could always be the ISP line causing the some of the drops.
the cable connections page and the event logs could help check that.
