Vinshamr
Dec 25, 2024Aspirant
C7000V2 Want to upgrade to wifi 6
I hope this is the correct board... I currently have a C7000V2 which I have been using without issues for about 5 years or so. I recently upgraded my VR setup to use a standalone headset but my wifi ...
Dec 26, 2024Guru - Experienced User
What speeds do you pay for?
Who's your isp?
The C7000 is a pretty solid modem but it probably maxes out around 300mbps over wireless (should still be plenty for streaming)
- VinshamrDec 26, 2024Aspirant
I have Spectrum and my plan is 600 Mbps. The modem says it maxes out at 600 for the 5GHz band.
- plemansDec 26, 2024Guru - Experienced User
You won't hit 600mbps over 5ghz on that device. 300-400mbps are about what the 5ghz will max out on for actual throughput. (not the link speed, that actual throughput)
Might be coming up on time for an upgrade as spectrum is only approving that device to 500mbps anymore.
You could still use that modem but they might not approve it to the faster speeds.
You could put it in modem only mode and connect any router you choose it it for upgrading.
https://www.spectrum.net/support/internet/compliant-modems-charter-network
I didn't realize the ISP could limit based on the device to a speed lower than my plan, that's good to know. Going back to one of your original comments where you said 300 should be plenty for streaming, does this mean my issue could potentially have nothing to do with my hardware and plan (and this is not the place to get it sorted)?
