Sashen
Mar 22, 2020Tutor
C7000v2 WAY slower than Xfinity modem
I just signed up for 600Mb Download speed from Xfinity. I've BEEN using a C7000v2 with Xfinity for a while, but when I upgrade to the new speed I ran a speed test (WiFi) and get about +/- 260Mb. ...
Mar 23, 2020Guru - Experienced User
What are you wired speeds thru the NG modem?
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
- SashenMar 23, 2020Tutor
I no longer own a computer with an ethernet port.
The Xfinity gives about 700Mb down via WiFi.
The NG gives about 260.
- FURRYe38Mar 23, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem?
Check the specs on the C7000v2, WiFi connection rates are:
(600 Mbps @2.4GHz with 256 QAM support +1300 Mbps 5Ghz 11ac)†
You need to check your wifi connection rates with WiFi Sweet Spots app loaded on your wireless devices.
- SashenMar 24, 2020Tutor
There's no indication on the Xfinity modem of who the manufacturer is.
My C7000v2 is set up with those specs.
My computer is 3' away from the modem, so Sweet Spots isn't telling me anything meaningful.
