stonecoldjedi
May 18, 2023Tutor
C7000v2 Wifi connected without internet, then goes back to normal
My C7000v2 has been having issues over past few days. All started after the weekend when we disconnected and repainted the living room. Since then, the Wifi signal suddenly stalls, shows Connected wit...
stonecoldjedi
May 18, 2023Tutor
Never removed the wall plate.
Here is event log
May 18, 2023Guru - Experienced User
All Criticals, Errors and Warnings seen in the event logs needs to be reviewed and resolved by the ISP.
Here is event log
- plemansMay 18, 2023Guru - Experienced User
If you check all the connectors and they're fine, then the ISP needs to check the line.
