stonecoldjedi
May 17, 2023Tutor
C7000v2 Wifi connected without internet, then goes back to normal
My C7000v2 has been having issues over past few days. All started after the weekend when we disconnected and repainted the living room. Since then, the Wifi signal suddenly stalls, shows Connected wit...
CoolhandLW
May 27, 2023Aspirant
That sounds like the exact same problem. Provider is blaming the hardware and Netgear is blaming the provider. The outages are annoying but only last a few minutes at most. Just enough to make me take a break from work, have streaming cut off, and for my son to scream about getting kicked off of Roblox.
I will watch your thread too. Hope you find the solution. Please post if you do!
- stonecoldjediJul 04, 2023TutorHello all. In a delayed follow-up, a couple weeks ago, my internet just randomly started working normally without any drops. Then, Xfinity followed up thru the Twitter DMs I had initiated with them. It appears there was an issue in my area. They didn't go into specifics, but a tech looked into supposedly and the issue is fixed. Internet is running smoothly and perfectly. Thank goodness I didn't spend $$ on a new device or start (gulp!) renting from them.
- FURRYe38Jul 04, 2023Guru - Experienced User
Glad they got it working on the ISP side.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
