CJinVA
May 11, 2020Guide
C7000v2 WIFI on/off Button is Blinking Green
All of a sudden yesterday I was getting very poor download speeds. Then in the evening it was fine again. It was fine this morning, but is now very slow again, IE 5MB/S. It is usually about 140. ...
May 11, 2020Guru - Experienced User
Do you have a screen snip of the cable connection page and logs?
That helps check the connection back to the isp.
Is it all devices having issues, just wired devices, just wireless devices?
I've never heard of the wifi on/off button blinking. its usually on or off depending on what its set at.
CJinVA
May 11, 2020Guide
The log is attached.
- CJinVAMay 11, 2020Guide
Ignore this one.
This are the most recent events from the event log.
- plemansMay 12, 2020Guru - Experienced User
You need to check your line. your power it all over the place, channels aren't locked properly, and you have a ton of errors.
Remove all splitters, attenuators, amplifiers from your line and directly connect the modem right where it enters the home. take a screen snip after doing that and repost it here. If its the same, then the isp needs to check your lines.
