wound_up
Jul 06, 2024Aspirant
C7000V2 wifi speed issues - wired speeds just fine
I'm setting up a new Nighthawk WiFi Cable Modem Router (Model 7000v2) on firmware V1.03.08. When Comcast/Xfinity came out they were getting speeds of 1200 Mbps straight from the line. When connectin...
- Jul 07, 2024
What WiFi devices are you connecting to the modem?
You sure they are connecting to the 5Ghz radio?
wound_up
Jul 14, 2024Aspirant
Yep - that was indeed the issue. My devices were not connecting to the 5GHz radio. đ I had wrongly assumed this would happening automatically. Thank you.
Jul 15, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. đĄ
