Annakat11
Aug 14, 2020Aspirant
C7000v2 will not communicate over WiFi to a Canon C7020 multifunction printer.
Keep getting error message that computer can't communicate with printer But It works with Ethernet over LAN. Windows 10 OS Also keep getting error message that internet connection has been in...
Aug 17, 2020Guru - Experienced User
Please check with the printers mfr on troubleshooting there product.
- Annakat11Aug 17, 2020Aspirant
I have contacted Canon and they say it is a router or ISP problem.
- FURRYe38Aug 17, 2020Guru - Experienced User
Be sure the FW on the printer is up to date.
Test the printers wifi out by disabling WPA security temporarily on the Modem. See if the printer will connect to the modems wifi with out any security. If it does, set WPA and TPIK then re-connect the printer again. See if it connects. Then try WPA2 and AES. if it fails here, then the printers wifi security may not support WPA2 and AES security mode setting. This would be a printer problem as WPA2 and AES is mostly more secure than WPA an TPIK mode.
