LanaTucker's avatar
LanaTucker
C7000v2 will not connect with my new Lenova desktop. Says password is not correct.
  • plemans's avatar
    Maybe its not correct?
    have you went into the lenovo and forgot the network ssid/password and then redid it?
  • michaelkenward's avatar
    michaelkenward
    What does "will not connect with my new Lenova desktop" mean?
    The desktop won't connect to the wifi from the C7100V? Your PC throws up an error of some sort with a wired connection? Something else?
    You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
    Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
    Cable Modems & Routers
    I will ask the Netgear moderator to move your message.
