AZhermit
Aug 28, 2020Tutor
C7000v2, Windows 10
How do you folks disconnect your USB NAS drive without corrupting data by just yanking out the USB connector? I don't see any way on the Nighthawk app or the old Genie desktop app to safely disconne...
- Aug 31, 2020
I would try to make sure that there is no data being written to the SSD before powering off the modem or pulling the USB cable. Usually there isn't any data being written if your not actively using the SSD or putting files to the drive. There maybe some reads being done by the modem system, however these shouldn't impact any files if the power or the USB is pullied.
AZhermit
Aug 31, 2020Tutor
FURRYe38 wrote:No, I would not do that as it might cause problems, if the usb SSD is working otherwise on it's own and gets power thru the modem, there shouldn't be any need for any additional power.
OK. I don't want to beat this into the ground, but... so then if data was being written to the SSD when I pull out the power supply from the modem (powered down) then I guess you are saying that would not result in any corruption of that data?
Aug 31, 2020Guru - Experienced User
- AZhermitSep 01, 2020Tutor
FURRYe38 wrote:I would try to make sure that there is no data being written to the SSD before powering off the modem or pulling the USB cable. Usually there isn't any data being written if your not actively using the SSD or putting files to the drive. There maybe some reads being done by the modem system, however these shouldn't impact any files if the power or the USB is pullied.
I do have the ability to "deny access" to any of the 11 devices connected to my network in the discontinued Netgear Genie app .So, I'll do that before powing down the modem. In the mean time I'm looking into SSDs with "Power Loss Protection". That looks like interesting tech.
https://www.samsung.com/semiconductor/minisite/ssd/support/faqs-03/ Scroll down 3/4 of the way. "What is the Power Loss Protection Feature..."
Thanks a lot for the input.I appreciate your time.
- FURRYe38Sep 01, 2020Guru - Experienced User
Good Luck. :smileywink:
- AZhermitSep 03, 2020Tutor
I thought I'd add this note for the benefit of the community.
I swapped out my Samsung 860 Evo SSD for a Crucial MX500 1TB
because of its "Integrated Power Loss Imunity" feature.
