Jamar27davis
Aug 17, 2022Aspirant
C7000v2 works for certain devices
I bought this Netgear Modem Router but it only works on my iPhone and MacBook, not my Roku stick or TV. I have Skywire (DirectTV) internet they said it's not the service it's the router. Please help I...
Aug 17, 2022Guru - Experienced User
Skywire? the C7000 is a modem/router combo device.
I didn't know that skywire had coaxial service.
Did it work when you were using cox?
What error are you getting?
Jamar27davis
Attached is a picture of the setup (Ethernet from wall to modem and coax from wall to tv). Cox gave me a router I didn't need to buy one (I was just pointing out that I never really had to deal with this)... however I just bought this Netgear one from Walmart because I was told to. The error only comes in with my ROKU tv which needs wifi to watch Netflix and such as of now I can only watch regular live TV: "It's showing up on my tv as a network but once I put in the password it says the network cannot connect reset router or check password"
- plemansAug 17, 2022Guru - Experienced User
Well, I don't see a photo.
But like I said, the C7000 is a coaxial modem. Meaning it needs a coax input from your isp. If you're isp's signal is coming in over an ethernet connection, its not compatible.
- Jamar27davisAug 17, 2022AspirantSo should I buy a different modem?
You should contact your ISP for compatible devices.
You might just need a router only device and not a modem/router combo device that you have
