midian5214
May 24, 2022Aspirant
C7000x2 cutting out on and off the past week , and the Nighthawk app won't let me into my router.
Hello, Hey FURRYe38 I'm again... or anyone else that can help.?. My C7000x2 has been going on and off with connecting to the internet several times a day for the past week or two. Usually, I would ...
May 24, 2022Guru - Experienced User
I would Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 10 seconds then let go. Then log in to routerlogin.com or 192.168.0.1 or .1.1 using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
How do you have Advanced wifi settings configured?
- midian5214May 24, 2022Aspirant
Hey FURRYe38,
My PC is already wired to the modem wifi router, and I did the reset, went to the http://192.168.0.1 page and there it went to the Netgear page, telling basically to down load/use the Nighthawk app which I tried earlier(no Genie anymore), and it won't let me get past the "Change Admin Password"(which I mentioned earlier). So, I did the http://192.168.1.1 page, and that one says "Page can't be found".?.
I've tried everything that I could think of that has worked in the past weeks, but not being able to get into the Nighthawk app, with it "saying that the modem/router isn't set up".?? Go through the set up till the Admin password change, and that's where it won't take any PW I configure to go on to the next page... I'm lost...
