sbordetsky's avatar
sbordetsky
Follower
Oct 29, 2022
C71000v want to reset wifi password.
I do not remember the wifi password that was set so I can't edit it since it asks for the "old" password. I have tried the reset pin hole and the lights went out but still unable fix it.
1 Reply
  • plemans's avatar
    the wifi password isn't the same as the password to lot into the router gui.
    If you factory reset it, to log into the router the defaults are:
    login: admin
    password: password
    Those require you to change the password when you first log in.
    did you do this?
