BrentO
Jul 20, 2017Tutor
C7100V - Can't connect to Skype
I just switched to Comcast. I bought the Netgear C7100V Modem/Router instead of renting from Comcast. Everything seems to work fine, except I can't connect to Skype. When I open Skype (program) and ...
vkdelta
Jul 20, 2017NETGEAR Employee Retired
can you please give a screenshot of the error?
did you disable any uPnP settings on C7100V?
Is it possible for you to capture traffic on your using wireshark?
- BrentOJul 21, 2017Tutor
I have installed Wireshark, but I'm not familiar with it and don't know how to use it.
I was having trouble uploading photos to Netgear, so I posted a screen shot of UPnP settings and the Port Forwarding Error -> https://photos.app.goo.gl/7PTJ9a1IOad1cvP13
Thanks for your help!
