2bornot2b
Jan 03, 2022Follower
C7100v - Orange light on ethernet port #4
(2) comuters using ethernet cables connections to my C7100v modem. There are (4) ethernet inputs on back on modem. primary home computer connected (ethernet cable). work computer connected via ethe...
Jan 03, 2022Guru - Experienced User
Make sure the work PCs network adapter is set up and enabled and configured properly. Check with work IT department to make sure the ethernet adapter is fully configured and functional for home use.
Make sure the ethernet adapter drivers on the work PC is updated.
Check other lan ports with the work PC to see if same thing happens on other ports.
Be sure your using a good quality LAN cable. CAT6 is recommended.
