types24
Feb 17, 2020Tutor
C7100V - Traffic Meter / Data Usage
For the last 7 weeks now, Comcast has been telling me I'm exceeding my bandwidth allowance, but this seems extremely unlikely to me. Is there any way to see which devices are using my bandwidth? Co...
- Feb 17, 2020
the C7100v doesn't have a "by device" traffic monitor. Its the most requested feature on the "ideas for home" page.
What you can do and what I've done is to use comcasts data monitor. they have one built into their services. so if you log into your comcast account through the browser, it has a monitor.
What I've done is see how much data I'm using on a daily basis and then shut off a few of my higher bandwidth devices. If the data drops off, its those devices. If it doesn't. something else is using the data. In that case, you can log into your attached devices list or your access control list. You can even disable devices from the access control list. By selectively disabling them and seeing how your data changes with comcast, you can tell which one is using all the data.
Its a gimmicky way around something that should be built into all the routers. With all the data caps out there, every router should have data monitoring by device.
Feb 17, 2020Guru - Experienced User
- types24Feb 17, 2020Tutor
Thanks, I'll give it a shot and report back. I also turned the traffic meter on the router back on and we'll see if that seems to work any better this time around.
- types24Feb 19, 2020TutorI’ve been trying the trial and error or blocking access to certain devices and watching the traffic meter. I’d have more confidence in this if my traffic meter was more reliable - is there a fix for it?
Anyway, so far it’s appearing like the culprit is my Amazon Echo Dot. I want to keep an eye on things for another day or so before I declare victory, but it looks like that may be what’s downloading ~30-40GB/day. Why? I have no idea. We barely use it and even if we did that amount of data seems impossible. But that will be a discussion for Amazon.- plemansFeb 20, 2020Guru - Experienced User
types24 wrote:
I’ve been trying the trial and error or blocking access to certain devices and watching the traffic meter. I’d have more confidence in this if my traffic meter was more reliable - is there a fix for it?----Not really. You can use the comcast data meter on their website. I've found that to be easier to use.
Anyway, so far it’s appearing like the culprit is my Amazon Echo Dot. I want to keep an eye on things for another day or so before I declare victory, but it looks like that may be what’s downloading ~30-40GB/day. Why? I have no idea. We barely use it and even if we did that amount of data seems impossible. But that will be a discussion for Amazon. - FURRYe38Feb 20, 2020Guru - Experienced User
Do you keep the Dot audio unmuted or muted? I keep mine muted. Thought I haven't tracked data usage and only have it accessing my NEST controllers and linked to Amazon and get notifications and thats about it. Mines a 1st gen Dot.
Anyway, so far it’s appearing like the culprit is my Amazon Echo Dot. I want to keep an eye on things for another day or so before I declare victory, but it looks like that may be what’s downloading ~30-40GB/day. Why? I have no idea. We barely use it and even if we did that amount of data seems impossible. But that will be a discussion for Amazon.- types24Feb 20, 2020Tutor
Unmuted, but no way should it be using so much data. Nor do I think it's normal; I'll report back what I hear from the nice people at Amazon.
