Omne
May 07, 2017Aspirant
C7100V access problem
HI, I have a C7100V that I am trying to connect to Comcast. Everything allegedly looked fine on their end but nothing was coming out as far as my pc or a wired device that was connected. Since I ...
DarrenM
May 11, 2017Sr. NETGEAR Moderator
Hello Omne
Did you check and see if your pc is getting a Ip address if so can you check the default gateway?
https://kb.netgear.com/20878/Finding-your-IP-address-without-using-the-command-prompt
DarrenM
Omne
May 11, 2017Aspirant
Hi,
Actually after talking to your tech people it turned out to be defective so I had to return it.
- Swheele1May 15, 2017Aspirant
I have the same problem. Received the unit today, contacted Comcast. No help. I wish you guys had phone support that I didn't have to pay $50 for so I could have confirmed that the unit doesn't work. I'm returning it tomorrow. :(
- OmneMay 16, 2017Aspirant
Actually I had 90 days of phone support with the purchase. It didn't cost me anything to call them.
