jtrech
Jun 17, 2020Follower
c7100v Amazon Version limits?
Hello, About 18 months ago I bought the C7100v from Amazon and had an Xfinity Plan with up to 300mbps. I just went and upped my service to 600. However I didn't relaize until after i did this that ...
Jun 17, 2020Guru - Experienced User
I see the spec sheet shows up to near 900Mbps for the 7100 series modem:
https://www.netgear.com/images//datasheet/networking/CableModems/C7100V.pdf
24x8 channel bonding.
Make sure your modem is using 24x4 or 8 channels. Something to contact the ISP about and see.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
