starone
May 14, 2017Aspirant
C7100V Bridge Mode
I have a CM600 that connects to the WAN port on Sonicwall firewall which serves as the main router for my network. I was told on Amazon's Q/A section on the product page that I could use the C7100V ...
starone
May 16, 2017Aspirant
Thank you!
Just so I'm sure I know what to do... After turning off NAT mode I can connect the WAN port on my Firewall to any of the ethernet ports on the C7100V and it will function just like my CM600?
Thanks again,
Scott
starone
Actually Netgear support just told me that will not engage Bridge Mode. Bridge Mode will be available in the next firmware release. However, if I disable NAT mode I can connect it and it will work in my configuration with just an extra hop for now.
