RIRed
Apr 16, 2022Tutor
C7100v compatible with Comcast 900mbps
I have voice/internet/TV with Comcast, had had their 300mbps service, getting about 115mbps download and 23mbps upload speed on wifi on a 2020 Macbook Pro (802.11n/ac and no ethernet port) running Mo...
- Apr 17, 2022
Your power levels look fine.
But you probably bought the wrong device if you're wanting close to gigabit speeds.
The C7100v isn't docsis 3.1 (only 3.0) compatible and xfinity's (and other isp's) have been pushing to require docsis 3.1 devices for lower and lower speed tiers. I'm impressed they even said they'd allow it for their 800mbps tier as ISP's like cox are requiring docsis 3.1 for anything 400+.
Also, you won't hit 400+ over wireless on that device. Only on wired.
One thing you can do is power off the modem and disconnect it from the coax. Give it a couple minutes and then reconnect the coax and boot it back up. Maybe xfinity didn't push the correct provisioning to it (or push it at all). Something to check on.
RIRed
Apr 17, 2022Tutor
Thank you Furry.
I was hoping to see a difference from the 300mbps service(actual download speed on mine of 120mbps). I was surprised to have minimal change. Spouse's work laptop (Windows) does have ethernet, got a speed of 250mbps wired. 50 on Wifi, on the alleged 900mbps plan.
Apr 17, 2022Guru - Experienced User
How are you testing the speed?
On the hardwired computer, try using xfinity's speedtest site.
And if you have more than 1 computer you can hardwire in, try that one as well in case its a computer issue.
- RIRedApr 18, 2022Tutor
I used speedtest at xfinity.com. This morning over wifi still using my Macbook Pro mfr 2020 (802.11a/b/g/n/ac) it was 101mbps. Also tried Ookla which gave download speed of 97.1, ping 12ms. I had tried last night with my spouse's Dell using an ethernet cable, got 250mbps on the xfinity speedtest. The only other computer we own with an ethernet port is a very old Macbook Pro (2012ish) that I can't get to power on. Called Xfinity again after trying Pleman's suggestion of unplugging the coaxial cable and modem power, then reattaching/restarting with, alas, no improvement. CS rep said I really am getting the 900mbps service to the house. The Xfinity tech is coming on Friday to see if there's a wiring issue.
- KalopotatoJul 14, 2022Aspirant
I am having similar issues. I pay for 600 mbps, but only get 291 mbps per xfinity speed test.
I am also having a xfinity rep come out to check stats. Is there any setting within modem that I can change or do, to increase speeds?
- plemansJul 15, 2022Guru - Experienced User
Kalopotato Have you started your own thread? its better to start your own so your details don't get mixed up with the OP's.
