RIRed
Apr 16, 2022Tutor
C7100v compatible with Comcast 900mbps
I have voice/internet/TV with Comcast, had had their 300mbps service, getting about 115mbps download and 23mbps upload speed on wifi on a 2020 Macbook Pro (802.11n/ac and no ethernet port) running Mo...
- Apr 17, 2022
Your power levels look fine.
But you probably bought the wrong device if you're wanting close to gigabit speeds.
The C7100v isn't docsis 3.1 (only 3.0) compatible and xfinity's (and other isp's) have been pushing to require docsis 3.1 devices for lower and lower speed tiers. I'm impressed they even said they'd allow it for their 800mbps tier as ISP's like cox are requiring docsis 3.1 for anything 400+.
Also, you won't hit 400+ over wireless on that device. Only on wired.
One thing you can do is power off the modem and disconnect it from the coax. Give it a couple minutes and then reconnect the coax and boot it back up. Maybe xfinity didn't push the correct provisioning to it (or push it at all). Something to check on.
Kalopotato
Jul 15, 2022Aspirant
I am having similar issues. I pay for 600 mbps, but only get 291 mbps per xfinity speed test.
I am also having a xfinity rep come out to check stats. Is there any setting within modem that I can change or do, to increase speeds?
Jul 15, 2022Guru - Experienced User
Kalopotato Have you started your own thread? its better to start your own so your details don't get mixed up with the OP's.
