packer22
Jan 16, 2023Aspirant
C7100V Ethernet Connectivity
I have a C7100V and my internet speed when checked through Xfinity is about 200 mbps. My desktop is connected to the modem via an ethernet cable. The desktop internet works well until my wife starts...
Jan 16, 2023Guru - Experienced User
Do any other devices have issues when she's streaming?
Reason I ask is 200mbps is more than enough to stream a couple 4k streams. It shouldn't be a bandwidth issue.
So I'd be either looking at the pc or at anything like qos, parental controls, traffic monitoring that could be causing issues.
packer22
I can use my mobile device without and get a good Wi-Fi connection. I will check out some of the other controls you suggested.
