arniem
Apr 15, 2020Guide
c7100v firmware v 2.01.42 internet and phone issue .
I have a C7100V firmware V2.01.42 cable modem router with phone connected to comcast. Every couple days or so the Wi Fi slows way down and the phone starts chopping/cutting in and out the incoming vo...
- Apr 16, 2020
Its worth a shot. It shouldn't necessarily cause the issue your having but having the network setup right is only going to be beneficial for troubleshooting.
Apr 15, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
