arniem
Apr 15, 2020Guide
c7100v firmware v 2.01.42 internet and phone issue .
I have a C7100V firmware V2.01.42 cable modem router with phone connected to comcast. Every couple days or so the Wi Fi slows way down and the phone starts chopping/cutting in and out the incoming vo...
- Apr 16, 2020
Its worth a shot. It shouldn't necessarily cause the issue your having but having the network setup right is only going to be beneficial for troubleshooting.
Apr 15, 2020Guru - Experienced User
when you click on reply, its the "choose file" option at the bottom of the text box.
arniem
Apr 15, 2020Guide
Yes do have channels set to manual thanks. Will try to load pics.
- arniemApr 15, 2020Guide
heres the other hope there the right ones.
- plemansApr 15, 2020Guru - Experienced User
When you reboot, it clears those out. Next time you're having the issue, log in and get the same screen snips. Problem is that it shows the values at that specific time you open the page. It'd be worth it to see what they're at when you're having issues.
You can always have the isp check the lines but they might not do a whole lot if its in a working state.
And again, if there's any splitters, amplifiers, attenuators in line, remove them.
Ps. I don't know if I've ever seen the correctables that close together with the 31-32-33. Usually you get a bit of variation.
Ok thanks probably within next day or so it will mess up i will get those snips again.
