arniem
Apr 15, 2020Guide
c7100v firmware v 2.01.42 internet and phone issue .
I have a C7100V firmware V2.01.42 cable modem router with phone connected to comcast. Every couple days or so the Wi Fi slows way down and the phone starts chopping/cutting in and out the incoming vo...
- Apr 16, 2020
Its worth a shot. It shouldn't necessarily cause the issue your having but having the network setup right is only going to be beneficial for troubleshooting.
Apr 16, 2020Guru - Experienced User
did you put the belkin in AP (access point) mode? or disable its routing function? running 2 routers on the same network can create issues.
https://kb.netgear.com/30186/What-is-Double-NAT
arniem
Apr 16, 2020Guide
No I did not I come out of Belkin ethernet port and go to garage computer. So maybe thats causing my problems?
- plemansApr 16, 2020Guru - Experienced User
- arniemApr 17, 2020Guide
It appears that was it I don't have any correctables or uncorrectables been running for 1 day so far with no drop in speed or phone problems . I will keep my fingers crossed . Well again I sure do appreciate all the advice thanks.
