OlivierHelme
Jan 12, 2020Follower
C7100V how to setup simultaneously the 2 bands?
michaelkenward
Jan 13, 2020Guru - Experienced User
If you visit the support pages:
Support | NETGEAR
you can feed in the model number and find all the documentation for your hardware.
You can find the model number on the label on the device.
By the way, it may not matter, but you have posted your message in the section of this community given over to Cable Modems, Routers and DSL Modems. (This is easily done, given Netgear's impenetrable community structure.)
If you need more help, you might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Cable Modems & Routers
No need to repost there, unless you want to – that will just clutter up the place with duplicated messages – but you might find advice related to your hardware.
schumaku
Jan 26, 2020Guru - Experienced User
Check the fine AC1900 Cable Modem Voice Router Model C7100V User Manual p.81 ff: Specify Basic WiFi Settings
